Saltar al contenido principal
Motorola Droid RAZR Display Assembly Replacement
David Hodson
David Hodson y 3 otros contribuidores
Última actualización: January 5, 2015
Sin estimación
Difícil
Guía Destacada
Introducción
Ir al paso 1
Did you heave your Droid RAZR through a metropolitan area in an attempt to recreate the lamppost slicing skills Motorola showed in their commercials? No? Well, even if you only dropped your phone down a couple flights of stairs, this guide will show you how to replace the display assembly.
The LCD and digitizer are fused to the display glass, so the entire unit must be replaced as one piece.
Qué necesitas
Herramientas
Ver más…
  1. Motorola Droid RAZR Display Assembly Replacement, Back Cover: paso 1, imagen 1 de 2 Motorola Droid RAZR Display Assembly Replacement, Back Cover: paso 1, imagen 2 de 2
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Display Assembly Replacement: paso 2, imagen 1 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 2, imagen 2 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 2, imagen 3 de 3
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Display Assembly Replacement: paso 3, imagen 1 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 3, imagen 2 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 3, imagen 3 de 3
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
  4. Motorola Droid RAZR Display Assembly Replacement, Battery: paso 4, imagen 1 de 2 Motorola Droid RAZR Display Assembly Replacement, Battery: paso 4, imagen 2 de 2
    • Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
  5. Motorola Droid RAZR Display Assembly Replacement: paso 5, imagen 1 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 5, imagen 2 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 5, imagen 3 de 3
    • Remove the two 3.3 mm T5 Torx battery terminal screws.
    • Grab the blue battery removal tab and lift the battery out to remove it.
    • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
    • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
  6. Motorola Droid RAZR Display Assembly Replacement, Camera Cover: paso 6, imagen 1 de 2 Motorola Droid RAZR Display Assembly Replacement, Camera Cover: paso 6, imagen 2 de 2
    • Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
    • The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
    • Gently pry up the bottom edge of the camera cover with a plastic opening tool.
    • Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
    • Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
  7. Motorola Droid RAZR Display Assembly Replacement: paso 7, imagen 1 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 7, imagen 2 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 7, imagen 3 de 3
    • Insert the plastic opening tool underneath the top edge of the camera cover.
    • Gently pry the camera cover up as you slide the plastic opening tool across the top edge to free it from the adhesive.
    • Remove the camera cover.
  8. Motorola Droid RAZR Display Assembly Replacement, Rear Case: paso 8, imagen 1 de 1
    • Remove the six screws securing the rear case to the rest of the phone:
    • three 6.7 mm silver T3 Torx screws at the top,
    • four 4.0 mm gold T3 Torx screws in the middle,
    • and three 4.5 mm black T5 Torx screws at the bottom.
  9. Motorola Droid RAZR Display Assembly Replacement: paso 9, imagen 1 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 9, imagen 2 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 9, imagen 3 de 3
    • Insert a plastic opening tool between the rear case and the motherboard assembly.
    • Work your way down the side of the phone and gently pry the rear case up.
    • Separate the rear case from the motherboard assembly.
  10. Motorola Droid RAZR Display Assembly Replacement, Motherboard Assembly: paso 10, imagen 1 de 2 Motorola Droid RAZR Display Assembly Replacement, Motherboard Assembly: paso 10, imagen 2 de 2
    • Remove the three 2.5 mm T3 Torx screws securing the metal chassis to the motherboard.
    • Remove the metal chassis from the motherboard assembly.
  11. Motorola Droid RAZR Display Assembly Replacement: paso 11, imagen 1 de 2 Motorola Droid RAZR Display Assembly Replacement: paso 11, imagen 2 de 2
    • Use the flat end of a spudger to remove the two red silicone microphone covers at the top and bottom of the motherboard.
  12. Motorola Droid RAZR Display Assembly Replacement: paso 12, imagen 1 de 1
    • There is a small metal shield that covers the display assembly cable connectors on the motherboard. This shield is held in place by a few small clips that attach to the surrounding EMI shields.
    • Use the tip of a spudger to gently bend the clips out of shape and remove the shield.
  13. Motorola Droid RAZR Display Assembly Replacement: paso 13, imagen 1 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 13, imagen 2 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 13, imagen 3 de 3
    • Use the flat end of a spudger to pry the three display cable connectors off their sockets on the motherboard.
  14. Motorola Droid RAZR Display Assembly Replacement: paso 14, imagen 1 de 2 Motorola Droid RAZR Display Assembly Replacement: paso 14, imagen 2 de 2
    • There are a number of small black plastic clips on the display assembly that hold the motherboard in place.
    • Release the securing clips with a plastic opening tool.
  15. Motorola Droid RAZR Display Assembly Replacement: paso 15, imagen 1 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 15, imagen 2 de 3 Motorola Droid RAZR Display Assembly Replacement: paso 15, imagen 3 de 3
    • Use a heat gun or hair dryer to soften the adhesive strip around the perimeter of the motherboard.
    • Pry the edges of the motherboard up from the display assembly with a plastic opening tool.
    • Remove the motherboard assembly.
  16. Motorola Droid RAZR Display Assembly Replacement, Display Assembly: paso 16, imagen 1 de 1
    • Once separated from the motherboard assembly, the entire display assembly can be replaced.
Conclusión
49 personas más completaron esta guía.
David Hodson
Miembro Desde 04/13/10
152,757 Reputación
127 Guías creadas
Un comentario
if the problem is charging point what should i do?
emmanuel.rambo75 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 63,179
