Saltar al contenido principal
MSI GP62MVR 6RF Leopard Pro Battery Replacement
Jordan Buck
Jordan Buck y 4 otros contribuidores
Última actualización: June 15, 2021
7 - 10 minutos
Fácil
Guía de Estudiante Destacada
Introducción
Ir al paso 1
This guide demonstrates how to replace the battery in the MSI GP62MVR 6RF Leopard Pro laptop. It is a simple process with no special skills required. Avoid touching the circuitry when the case is open to avoid short-circuiting components or shocking yourself. If the battery in your laptop doesn’t turn on, cannot charge, or loses charge rapidly, then it will need to be replaced. Follow this guide to change the battery in a MSI GP62MVR 6RF Leopard Pro.
Qué necesitas
Partes
Herramientas
Ver más…
  1. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: paso 1, imagen 1 de 2 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Battery Replacement: paso 2, imagen 1 de 2 MSI GP62MVR 6RF Leopard Pro Battery Replacement: paso 2, imagen 2 de 2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Battery Replacement: paso 3, imagen 1 de 1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: paso 4, imagen 1 de 3 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: paso 4, imagen 2 de 3 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
    • Remove the battery from the device.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 33
Todo El Tiempo: 1,480
