Saltar al contenido principal
Logitech Webcam Pro 9000 Front and Back Cover Replacement
Timothy Forrest
Timothy Forrest y 11 otros contribuidores
Última actualización: December 26, 2022
5 minuto
Fácil
Introducción
Ir al paso 1
Learn how to get to the interior of a Logitech Webcam Pro 9000. There are a few extra wires, so be careful not to pull the covers apart too quickly.
Qué necesitas
Herramientas
  1. Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: paso 1, imagen 1 de 2 Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: paso 1, imagen 2 de 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Front and Back Cover Replacement: paso 2, imagen 1 de 2 Logitech Webcam Pro 9000 Front and Back Cover Replacement: paso 2, imagen 2 de 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
Conclusión
Equipo
Cal Poly, Team 12-34, Amido Spring 2013 Miembro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 24
Todo El Tiempo: 1,311
