Logitech G29 Driving Force Buttons Replacement
Introducción
Ir al paso 1This guide explains how to remove and replace the buttons on the G29 Driving Force wheel.
If the buttons are malfunctioning, taking it apart could expose potential problems and allow for viable fixes rather than throwing the entire device away.
This process is not difficult and can be completed with little teardown.
Qué necesitas
Take off the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. The outer diameter of these screws are 8.40mm with a length of 26mm.
Herramienta utilizada en este paso:Tweezers$3.99
Once the PCB is out, the triangle, square, circle, x button will be exposed. Use the angled tweezers to remove all four buttons.
Remove the 4 black screws diameter of 3.41mm holding the 4 buttons in place using the Ph #00 bit. These are located directly under the buttons. The whole housing is not required to come out since only the blue buttons need to come out. Once the screws are removed the buttons will fall out.
