Linksys WRT54GS v2 Front Case Replacement
Introducción
Ir al paso 1In this guide you will remove the router's front case and begin to have access to the router's internal components.
Qué necesitas
Herramientas
Ver más…
Remove the rubber inserts inside the the two purple feet located on the router's front case.
This may be a challenge, so try the following two methods:
Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
Una persona más ha completado esta guía.
