Saltar al contenido principal
LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming
Luay Ghabayin
Luay Ghabayin y otro contribuidor
Última actualización: August 15, 2024
10 - 15 minutos
Moderado
Introducción
Ir al paso 1
Welcome! This guide will walk you through the process of replacing the battery and reprogramming your LiftMaster 893LM garage remote.
Garage remotes can become unresponsive over time due to dead batteries, leaving you with issues like accessing your garage. Replacing the battery and reprogramming the remote is an essential thing that ensures your remote remains functional.
By following this guide, you will learn how to safely replace the battery in your LiftMaster 893LM remote and reprogram it to work with your garage door opener. This not only extends the life of your remote but also saves you money.
Ensuring that your garage remote is in good working condition is essential for everyday convenience and security. Let's get started on making sure your LiftMaster garage remote is fully functional.
Qué necesitas
Partes
Herramientas
  • Spudger
    Spudger
Ver más…
  1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: paso 1, imagen 1 de 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: paso 1, imagen 2 de 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: paso 1, imagen 3 de 3
    • Use a spudger to gently pry open the remote case to access the battery compartment.
  2. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 2, imagen 1 de 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 2, imagen 2 de 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 2, imagen 3 de 3
    • Carefully remove the old battery using a spudger.
  3. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 3, imagen 1 de 2 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 3, imagen 2 de 2
    • Place the new battery into the compartment securely, noting the orientation of its positive and negative sides.
  4. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 4, imagen 1 de 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 4, imagen 2 de 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 4, imagen 3 de 3
    • Turn the remote upside down and push the cover gently until you hear a click, ensuring it is securely closed.
    • Align the cover to the remote buttons.
  5. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 5, imagen 1 de 2 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 5, imagen 2 de 2
    • Locate the garage door system on top of the garage and open it.
  6. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 6, imagen 1 de 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 6, imagen 2 de 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 6, imagen 3 de 3
    • Locate the learn button.
    • Press and release the receiver learn button.
    • Within 30 seconds, press and hold remote button.
    • When the opener light flashes, release the remote button which means the programming was successful.
  7. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 7, imagen 1 de 1
    • Press the remote button to ensure it opens and closes the garage door as expected.
    • If the remote does not work, repeat Step 6.
  8. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: paso 8, imagen 1 de 1
    • In case the remote fails and the garage door is closed, use the side-mounted wall remote for emergency access.
    • Press the green light.
Linea de Meta
Luay Ghabayin
Miembro Desde 07/02/24
157 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 9
Ultimos 30 días: 50
Todo El Tiempo: 630
