LifeTrak Zone C410 Battery Replacement
Introducción
Ir al paso 1This guide will show you the steps to replace the battery of the LifeTrak C410. Replacement battery can be found here.
Qué necesitas
Grasp the body of the watch between your thumb and your index finger.
Slide the band through its clasp.
Remove the four 5.24 mm screws using a Phillips #0 screwdriver.
Remove the back panel.
2 personas más completaron esta guía.
