Saltar al contenido principal
Lenovo Yoga 720-15IKB Speakers Replacement
Jeremy Kostel
Jeremy Kostel y 2 otros contribuidores
Última actualización: June 23, 2022
5 minuto
Fácil
Introducción
Ir al paso 1
This guide shows you how to replace the Lenovo Yoga 720 15-IKB (88YG7000828‎) speakers. This laptop is very similar to the Lenovo Yoga 720 13-inch , the Yoga 710, and the Yoga 730. Faulty speakers can cause audio to either be distorted or the computer to not produce audio at all. These symptoms are further explained on the troubleshooting page.
Qué necesitas
Herramientas
Ver más…
  1. Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: paso 1, imagen 1 de 3 Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: paso 1, imagen 2 de 3 Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Speakers Replacement: paso 2, imagen 1 de 2 Lenovo Yoga 720-15IKB Speakers Replacement: paso 2, imagen 2 de 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: paso 3, imagen 1 de 3 Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: paso 3, imagen 2 de 3 Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: paso 3, imagen 3 de 3
    • Here are the speakers for this device.
    • Pull the right speaker straight up and remove it from the computer.
    • As you remove the speaker, make sure to also carefully pull the wire connected to the speaker out along with the speaker.
  4. Lenovo Yoga 720-15IKB Speakers Replacement: paso 4, imagen 1 de 1
    • Remove the left speaker similarly to how the right speaker was removed.
  5. Lenovo Yoga 720-15IKB Speakers Replacement: paso 5, imagen 1 de 1
    • Unplug the speaker by firmly pulling the wire out of the socket.
Conclusión
Una persona más ha completado esta guía.
Jeremy Kostel
Miembro Desde 01/23/20
249 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S19-G3, White Winter 2020 Miembro de Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
Miembros de 4
25 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 450
