Saltar al contenido principal
Lenovo ThinkPad Yoga 370 Battery Replacement
Cassandra Shedden
Cassandra Shedden y 3 otros contribuidores
Última actualización: February 25, 2021
5 - 10 minutos
Fácil
Introducción
Ir al paso 1
For the Lenovo ThinkPad Yoga 370 (Model Number: 20JH002AUS), if the battery is not charging the device, it could be faulty and this guide will show step by step instructions on how to replace the faulty battery.
Caution: When replacing the battery, make sure the replacement battery is the exact same type as before. Replacement of a wrong battery could cause it to ignite.
Qué necesitas
Kits de reparación
Este kit contiene todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
Ver más…
  1. Lenovo ThinkPad Yoga 370 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Battery Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Battery Replacement: paso 2, imagen 2 de 2
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Battery Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Battery Replacement: paso 3, imagen 2 de 2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Battery Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Battery Replacement: paso 4, imagen 2 de 2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Battery Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad Yoga 370 Battery Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad Yoga 370 Battery Replacement: paso 5, imagen 3 de 3
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Battery Replacement: paso 6, imagen 1 de 3 Lenovo ThinkPad Yoga 370 Battery Replacement: paso 6, imagen 2 de 3 Lenovo ThinkPad Yoga 370 Battery Replacement: paso 6, imagen 3 de 3
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
Conclusión
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
Una persona más ha completado esta guía.
Un comentario
There’s a procedure you must do before removing any of the screws- disable the battery!
Ben Rossington - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 64
Todo El Tiempo: 6,281
