Saltar al contenido principal
Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement
Lex
Lex y 5 otros contribuidores
Última actualización: January 30, 2025
40 - 55 minutos
Moderado
Introducción
Ir al paso 1
If your Lenovo ThinkPad Yoga 11e Gen 6 has a broken screen, it may make it difficult to see the display properly. A cracked laptop screen is a serious injury hazard, as shards of broken glass may cut you or become imbedded into your skin. This guide will demonstrate how to safely replace the broken screen.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement, Screen: paso 1, imagen 1 de 2 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Wearing the anti-static wrist strap will prevent a static shock from damaging the components in the laptop.
    • Disconnect the laptop from power and make sure it is completely powered off.
    • Turn the laptop facing down.
    • Loosen the eight captive screws using a JIS #0 screwdriver.
    • The screws are attached to the panel and cannot be removed.
    • Carefully remove the panel.
  2. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: paso 2, imagen 3 de 3
    • Carefully disconnect the two sliding connectors in the left and right corner.
    • Disconnect the sliding connector on the Wi-Fi board.
    • Loosen the four 9.7 mm screws on the hinges in the top left and right corners using a Phillips #0 screwdriver.
    • Carefully lift the closest part of the laptop away from the screen side of the laptop.
  3. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: paso 3, imagen 3 de 3
    • Using tweezers, gently pry and remove the covers on the LCD strip.
    • Remove the two 3.3 mm screws that were previously under the covers on the LCD strip using a Phillips #0 screwdriver.
    • Carefully lift and remove the LCD strip.
  4. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: paso 4, imagen 3 de 3
    • Remove the two 3.3 mm screws from the silver panels using a Phillips #0 screwdriver.
    • Remove the two 3.3 mm screws from the LCD panel using a Phillips #0 screwdriver.
    • Carefully lift the screen towards you. You may use the spudger to assist lifting the screen. There will be one more connector on the side of the screen.
    • Carefully remove the ribbon connectors by gently pulling with your fingers.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 28
Todo El Tiempo: 90
