Lenovo ThinkPad X250 RAM/SSD Replacement
Introducción
Ir al paso 1If your running out of RAM, or don't have enough storage, try upgrading your thinkpad.
Qué necesitas
Unscrew the 8 screws holding the back panel in place.
Use a plastic prying tool to release all the clips holding the panel in place.
In the RAM slot, you will see 2 metal clips on either side. Pull on both and the ram will pop up.
Take out the stick of RAM.
Insert your new stick of RAM and push downwards.
Unscrew the SSD/HDD placer
Then, remove and pull the SSD/HDD out.
Put in your new SSD.
Re-Plug the SATA Connector.
Una persona más ha completado esta guía.
