Saltar al contenido principal
Lenovo ThinkPad X1 Extreme SSD Replacement
Addy Botao Liu
Addy Botao Liu y 5 otros contribuidores
Última actualización: January 17, 2025
15 - 25 minutos
Fácil
Necesita mejores imágenes
Introducción
Ir al paso 1
This guide will lead you through the steps to replace the SSD card on the Lenovo ThinkPad X1 Extreme Generation 1. The SSD card, or solid-state drive, acts as extra storage for the device, however, oftentimes the SSD can wear out, or run slower with age.
The steps to replace the SSD card are simple, the hardest part being keeping track of all the screws while taking apart the device.
It is important to remember to turn off the device while replacing the SSD card.
Qué necesitas
Kits de reparación
Estos kits contienen todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
Ver más…
  1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: paso 1, imagen 1 de 3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: paso 1, imagen 2 de 3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: paso 1, imagen 3 de 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: paso 2, imagen 1 de 2 Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: paso 2, imagen 2 de 2
    • Using the Phillips #00 screwdriver, remove the single screw securing the SSD to the motherboard.
  3. Lenovo ThinkPad X1 Extreme SSD Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad X1 Extreme SSD Replacement: paso 3, imagen 2 de 2
    • Using the opening tool, pop out the SSD card and remove it from the device.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Anyhow this laptop support gen 4 nvme or higher?
jordan chong - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 45
Todo El Tiempo: 2,316
