Saltar al contenido principal
Lenovo ThinkPad T570 RAM Replacement
Rylee Hjorth
Rylee Hjorth y 3 otros contribuidores
Última actualización: December 16, 2024
15 minuto
Moderado
Introducción
Ir al paso 1
This guide outlines how to replace the RAM in the Lenovo ThinkPad T570. Before proceeding, make sure the device is powered down and the battery is removed. There are many small and delicate parts on the inside of the computer, so use gentle and deliberate movements when working so the parts and pieces aren't damaged.
Qué necesitas
Herramientas
  1. Lenovo ThinkPad T570 RAM Replacement, Battery: paso 1, imagen 1 de 3 Lenovo ThinkPad T570 RAM Replacement, Battery: paso 1, imagen 2 de 3 Lenovo ThinkPad T570 RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Switch the left latch to the left to unlock the battery.
    • While holding the right latch to the right, slide the battery away from the device.
  2. Lenovo ThinkPad T570 RAM Replacement, RAM: paso 2, imagen 1 de 3 Lenovo ThinkPad T570 RAM Replacement, RAM: paso 2, imagen 2 de 3 Lenovo ThinkPad T570 RAM Replacement, RAM: paso 2, imagen 3 de 3
    • Loosen the seven captive screws on the back panel of the computer using a JIS #0 screwdriver.
    • The screws are designed so they do not come out of the laptop base, so twist the screwdriver until they are completely loosened.
    • Remove the back panel.
  3. Lenovo ThinkPad T570 RAM Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad T570 RAM Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad T570 RAM Replacement: paso 3, imagen 3 de 3
    • Push the clips outwards to release the RAM chip.
    • From there, take the chip out.
    • To add a new RAM chip, slide the chip in and press down to lock it in place with the clips.
Conclusión
Rylee Hjorth
Miembro Desde 09/04/24
277 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 61
