Lenovo ThinkPad T470S RAM Replacement
Introducción
Ir al paso 1This guide will show you how to replace a RAM stick in a Lenovo ThinkPad T470S laptop. RAM replacement may be necessary if there is an error in your RAM or if there is not enough RAM.
Qué necesitas
Partes
Herramientas
Ver más…
Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
Lift the bottom panel up and off the laptop.
Push out the spring-loaded mechanism that is holding the RAM stick in place.
Slide the RAM stick out.
2 personas más completaron esta guía.
