Saltar al contenido principal
Lenovo ThinkPad L440 Screen Replacement
Catherine Miller
Catherine Miller y 2 otros contribuidores
Última actualización: December 30, 2024
10 - 15 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to replace the screen on your Lenovo ThinkPad L440 laptop.
The screen is a vital component to the laptop, allowing the user to see visual representations on the computer. A failing screen will prevent you from accessing your computer. Some signs that your screen is failing are flickering, drawn out colors, a burnt display or burnt pixels. Also, if the screen has been previously cracked, this guide will fix this.
Note, if your screen is cracked from dropping the laptop, or your screen no longer works from water damage, this guide may not fix any screen related issues.
Before using this guide, consult our troubleshooting page. In some cases, what looks like a faulty screen can actually be related to outdated software, or too many background applications.
Qué necesitas
Herramientas
Ver más…
  1. Lenovo ThinkPad L440 Screen Replacement, Battery: paso 1, imagen 1 de 3 Lenovo ThinkPad L440 Screen Replacement, Battery: paso 1, imagen 2 de 3 Lenovo ThinkPad L440 Screen Replacement, Battery: paso 1, imagen 3 de 3
    • Open the laptop to access the power button.
    • Hold the power button in the top right until the computer powers off.
    • Turn the computer over so that the bottom of the computer is facing up
  2. Lenovo ThinkPad L440 Screen Replacement: paso 2, imagen 1 de 1
    • On the left side under the raised surface, move the tab to the left towards the unlocked symbol. Repeat this on the right side and move the tab to the right towards the unlocked symbol.
  3. Lenovo ThinkPad L440 Screen Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad L440 Screen Replacement: paso 3, imagen 2 de 2
    • From the top of the laptop, slide the raised surface away from the rest of the laptop and out of its slot to remove the battery from the computer.
  4. Lenovo ThinkPad L440 Screen Replacement, Screen: paso 4, imagen 1 de 1
    • Use the pointed tweezers to remove the coverings on the bottom left and right of the laptop’s screen.
  5. Lenovo ThinkPad L440 Screen Replacement: paso 5, imagen 1 de 1
    • Remove the two black 3 mm screws using a Phillips #0 screwdriver.
  6. Lenovo ThinkPad L440 Screen Replacement: paso 6, imagen 1 de 1
    • Using the plastic spudger and your fingers, pry off the plastic frame.
  7. Lenovo ThinkPad L440 Screen Replacement: paso 7, imagen 1 de 2 Lenovo ThinkPad L440 Screen Replacement: paso 7, imagen 2 de 2
    • Remove the two silver 2 mm screws under the frame using a Phillips #00 screwdriver.
  8. Lenovo ThinkPad L440 Screen Replacement: paso 8, imagen 1 de 1
    • With the pointed tweezers, peel back the adhesive and remove the screen.
Conclusión
To reassemble, follow these steps in reverse order. Turn on the laptop and test your new screen.
Catherine Miller
Miembro Desde 10/18/24
171 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 2-6, Konn Fall 2024 Miembro de UMass Dartmouth, Team 2-6, Konn Fall 2024
UMASSD-KONN-F24S2G6
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 27
Todo El Tiempo: 76
