Saltar al contenido principal
Lenovo N23 Chromebook Motherboard Replacement
Josh Keating
Josh Keating y 5 otros contribuidores
Última actualización: January 4, 2025
30 - 50 minutos
Moderado
Introducción
Ir al paso 1
This guide will show you how to replace the Lenovo N23 Chromebook motherboard.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Lenovo N23 Chromebook Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Lenovo N23 Chromebook Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Before starting, make sure that the laptop is powered off and completely unplugged from the charger.
    • Remove the eight 6.0 mm screws holding the back cover into place using a Phillips #0 screwdriver.
  2. Lenovo N23 Chromebook Motherboard Replacement: paso 2, imagen 1 de 1
    • Flip the device over.
    • Slide a plastic opening tool between the back cover and keyboard.
    • Carefully pry upwards until you hear a click.
    • Following the seam, slide the opening tool all the way around the front cover, prying upwards occasionally until the keyboard and trackpad are loose from the back cover.
    • Lift the keyboard panel up to reveal the internals.
    • Don't lift the keyboard panel too violently, as there is still a cable attachment to the motherboard.
  3. Lenovo N23 Chromebook Motherboard Replacement: paso 3, imagen 1 de 3 Lenovo N23 Chromebook Motherboard Replacement: paso 3, imagen 2 de 3 Lenovo N23 Chromebook Motherboard Replacement: paso 3, imagen 3 de 3
    • You can now access the internals of the computer.
    • Disconnect the two ribbon cables that connect from the motherboard to the front cover.
    • Using the iFixit opening tool, flip up the black tab holding the keyboard ribbon cable and then pull the cable out.
    • Using the opening tool, flip the white tab holding the mouse ribbon cable and then pull the cable out.
  4. Lenovo N23 Chromebook Motherboard Replacement: paso 4, imagen 1 de 2 Lenovo N23 Chromebook Motherboard Replacement: paso 4, imagen 2 de 2
    • Lift the keyboard panel from the case and fully remove it from the device.
  5. Lenovo N23 Chromebook Motherboard Replacement: paso 5, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the battery in place.
  6. Lenovo N23 Chromebook Motherboard Replacement: paso 6, imagen 1 de 3 Lenovo N23 Chromebook Motherboard Replacement: paso 6, imagen 2 de 3 Lenovo N23 Chromebook Motherboard Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery cable using a plastic opening tool by pulling on the black plastic lip.
    • Lift the battery out of the laptop.
  7. Lenovo N23 Chromebook Motherboard Replacement, Wifi Card: paso 7, imagen 1 de 3 Lenovo N23 Chromebook Motherboard Replacement, Wifi Card: paso 7, imagen 2 de 3 Lenovo N23 Chromebook Motherboard Replacement, Wifi Card: paso 7, imagen 3 de 3
    • Use a plastic opening tool to disconnect the two coaxial cables from the Wi-Fi card.
    • Tuck the two wires out of the way.
  8. Lenovo N23 Chromebook Motherboard Replacement: paso 8, imagen 1 de 3 Lenovo N23 Chromebook Motherboard Replacement: paso 8, imagen 2 de 3 Lenovo N23 Chromebook Motherboard Replacement: paso 8, imagen 3 de 3
    • Remove the single 3.0 mm screw holding the Wi-Fi card using a Phillips #1 screwdriver.
    • Using your hands, carefully pull the Wi-Fi card sideways out of the port on the motherboard.
  9. Lenovo N23 Chromebook Motherboard Replacement, Motherboard: paso 9, imagen 1 de 3 Lenovo N23 Chromebook Motherboard Replacement, Motherboard: paso 9, imagen 2 de 3 Lenovo N23 Chromebook Motherboard Replacement, Motherboard: paso 9, imagen 3 de 3
    • Remove the USB ribbon cable by lifting up on the white tab using a plastic opening tool and then pull the cable out.
  10. Lenovo N23 Chromebook Motherboard Replacement: paso 10, imagen 1 de 2 Lenovo N23 Chromebook Motherboard Replacement: paso 10, imagen 2 de 2
    • Disconnect the two black connectors on the bottom left side of the motherboard by pulling back on the lip with a plastic opening tool.
  11. Lenovo N23 Chromebook Motherboard Replacement: paso 11, imagen 1 de 3 Lenovo N23 Chromebook Motherboard Replacement: paso 11, imagen 2 de 3 Lenovo N23 Chromebook Motherboard Replacement: paso 11, imagen 3 de 3
    • Disconnect the video cable by lifting upwards on the black tab using a plastic opening tool and pulling the cable out.
  12. Lenovo N23 Chromebook Motherboard Replacement: paso 12, imagen 1 de 3 Lenovo N23 Chromebook Motherboard Replacement: paso 12, imagen 2 de 3 Lenovo N23 Chromebook Motherboard Replacement: paso 12, imagen 3 de 3
    • Remove the five 3.0 mm screws that hold the motherboard in place with a Phillips #0 screwdriver.
    • Lift the motherboard carefully out of the laptop being sure to not let it get caught on any cables.
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 31
Todo El Tiempo: 1,367
