Saltar al contenido principal
Lenovo Legion Y530-15ICH USB Port Replacement
Kimberly Caroline Winkler
Kimberly Caroline Winkler y 4 otros contribuidores
Última actualización: March 18, 2024
20 - 35 minutos
Fácil
Necesita mejores imágenes
Necesita más imágenes
Mejor introducción
Introducción
Ir al paso 1
This guide replaces the USB port for the Lenovo Legion Y530-15ICH, overtime with use it make break/get water damaged. This is especially important if the user needs to connect a smartphone.
Qué necesitas
  1. Lenovo Legion Y530-15ICH USB Port Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH USB Port Replacement: paso 2, imagen 1 de 2 Lenovo Legion Y530-15ICH USB Port Replacement: paso 2, imagen 2 de 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: paso 3, imagen 1 de 2 Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: paso 3, imagen 2 de 2
    • Remove the ribbon cable connecting the USB port to the motherboard, located adjacent to the fan unit.
    • Using a JIS #1 screwdriver, remove the two screws securing the USB port to the module.
  4. Lenovo Legion Y530-15ICH USB Port Replacement: paso 4, imagen 1 de 1
    • Gently disconnect the single ribbon cable with your fingers.
    • Remove the USB port from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 1,103
