Saltar al contenido principal
Lenovo Legion Y530-15ICH Solid State Drive Replacement
Kaylie Klausing
Kaylie Klausing y 4 otros contribuidores
Última actualización: November 15, 2022
5 - 10 minutos
Fácil
Introducción
Ir al paso 1
Each and every computer will need a permanent memory storage to store large amounts of data. Typically, a computer will include a hard drive, which is the standard form of storage. The solid state drive (SSD) loads and reads files faster than a standard hard drive, and are often lower in storage capacity. If your device is loading slower than normal or if you can’t access the files in your computer, your SSD may be corrupted and needs to be replaced.
This guide is to replace a faulty SSD or upgrade to an SSD with more capacity. Ensure that the computer is completely powered off and backups have been made before beginning this guide.
Qué necesitas
Kits de reparación
Estos kits contienen todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
Ver más…
  1. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Solid State Drive Replacement: paso 2, imagen 1 de 2 Lenovo Legion Y530-15ICH Solid State Drive Replacement: paso 2, imagen 2 de 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: paso 3, imagen 1 de 2 Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: paso 3, imagen 2 de 2
    • Do not remove the thermal pad.
    • Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
  4. Lenovo Legion Y530-15ICH Solid State Drive Replacement: paso 4, imagen 1 de 2 Lenovo Legion Y530-15ICH Solid State Drive Replacement: paso 4, imagen 2 de 2
    • Carefully remove the SSD from its connector.
Conclusión
Insert your new SSD into the connector. To reassemble your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S7-G1, Regan Winter 2020 Miembro de Cal Poly, Team S7-G1, Regan Winter 2020
CPSU-REGAN-W20S7G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 33
Todo El Tiempo: 5,533
