Saltar al contenido principal
Lenovo IdeaPad Flex 6-14IKB Battery Replacement
Ryan Reish
Ryan Reish y 5 otros contribuidores
Última actualización: February 4, 2025
1 hora
Muy fácil
Introducción
Ir al paso 1
This guide will show you how to replace the battery in your Lenovo IdeaPad Flex 6-14IKB. The battery is an essential part of the laptop because it is the energy storage device. The battery gives power to the laptop while it is not plugged into a charger. Your battery may need replacement if your laptop only powers on while plugged into a charger or it discharges very quickly when unplugged.
Before starting the replacement, make sure the laptop is fully turned off and unplugged from a power cord.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Lenovo IdeaPad Flex 6-14IKB Battery Replacement, Base Cover: paso 1, imagen 1 de 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Battery Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB Battery Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad Flex 6-14IKB Battery Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Disconnect the battery supply from the motherboard using a pair of tweezers.
    • Remove the battery from the laptop.
    • If the battery has an adhesive patch on the underside, gently pry off the battery.
Conclusión
7 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 60
Todo El Tiempo: 3,432
