Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement
Introducción
Ir al paso 1This is a touchpad removal guide for the Lenovo IdeaPad Flex 5 14ARE05. The touchpad is the built-in device that's responsible for your mouse input to the laptop. In this guide, you will remove the back panel, battery, and motherboard to reach the touchpad. If your touchpad is not functional or needs to be replaced for any other reason, use this guide. Make sure the laptop is powered down and disconnected from all power sources.
Qué necesitas
Remove the five 8 mm screws using a T5 Torx Screwdriver.
Remove the four 5 mm screws using a T5 Torx Screwdriver.
Remove the four 2 mm screws using a JIS #1 screwdriver.
Remove the three 5 mm screws using a JIS #1 screwdriver.
Pull on the blue tab to disconnect the large ribbon cable.
Pull on the blue tab to disconnect the small ribbon cable.
