Saltar al contenido principal
Lenovo G780 Fan Replacement
conneranisa1
conneranisa1 y 4 otros contribuidores
Última actualización: May 17, 2022
15 - 30 minutos
Moderado
Introducción
Ir al paso 1
This guide demonstrates fan removal and replacement for the Lenovo G780, which may be necessary in case of fan failure or to clean excessive dust buildup. By replacing your fan, your laptop will run more efficiently since it will be able to cool itself down with a properly functioning fan. There are no special skills required to complete this replacement.
Qué necesitas
Herramientas
  1. Lenovo G780 Fan Replacement, Battery: paso 1, imagen 1 de 2 Lenovo G780 Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Fan Replacement: paso 2, imagen 1 de 1
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Fan Replacement, Fan: paso 3, imagen 1 de 3 Lenovo G780 Fan Replacement, Fan: paso 3, imagen 2 de 3 Lenovo G780 Fan Replacement, Fan: paso 3, imagen 3 de 3
    • Remove the six 9 mm screws from the back panel with a Phillips #0 screwdriver.
    • Save these screws.
    • Remove the back plate.
  4. Lenovo G780 Fan Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #0 screwdriver to detach the fan by removing the two black 9 mm screws and the single silver 4 mm screw that is securing it to the motherboard.
  5. Lenovo G780 Fan Replacement: paso 5, imagen 1 de 2 Lenovo G780 Fan Replacement: paso 5, imagen 2 de 2
    • Carefully disconnect the fan cable from its socket on the motherboard.
    • The fan should now be completely free from the laptop motherboard and chassis.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 865
