Saltar al contenido principal
Lenovo G70-70 Battery Replacement
Joseph Crews
Joseph Crews y otro contribuidor
Última actualización: December 16, 2022
30 segundo - 1 minuto
Muy fácil
Introducción
Ir al paso 1
If your Lenovo G70-70 laptop does not respond to inputs or shows no signs of powering up, use this guide to replace the battery. The battery transfers its stored energy to the laptop to power it. A faulty battery will either power the laptop for a short period of time or not at all. Before using this guide, inspect the connection points on the battery for debris that may stop the battery from powering the laptop. Typically a small amount of debris can be blown away with a small dust blower. This repair is necessary so you can use your laptop while it is unplugged until the battery needs to be charged again. Before beginning, make sure to power off the laptop completely and disconnect from any external power source.
  1. Lenovo G70-70 Battery Replacement, Battery: paso 1, imagen 1 de 2 Lenovo G70-70 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure the battery is removed before attempting to fix anything on the laptop.
    • Orient the laptop so the bottom side is facing you.
    • To unlock the battery, place your thumb over the left switch and slide it to the left.
  2. Lenovo G70-70 Battery Replacement: paso 2, imagen 1 de 2 Lenovo G70-70 Battery Replacement: paso 2, imagen 2 de 2
    • To access the battery, place your thumb over the right switch and slide it to the right.
    • When the battery is unlocked, it will automatically pop up.
  3. Lenovo G70-70 Battery Replacement: paso 3, imagen 1 de 3 Lenovo G70-70 Battery Replacement: paso 3, imagen 2 de 3 Lenovo G70-70 Battery Replacement: paso 3, imagen 3 de 3
    • Remove the battery by lifting it up and away from yourself.
Conclusión
2 personas más completaron esta guía.
Joseph Crews
Miembro Desde 09/15/22
842 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 271
