Saltar al contenido principal
Lenovo G500S Touch Disc Drive Replacement
Christopher Foster
Christopher Foster y 2 otros contribuidores
Última actualización: January 14, 2020
5 minuto
Fácil
Introducción
Ir al paso 1
The disc drive in a laptop is a component that is likely to experience troubles overtime. You may hear clicking noises coming from the disc drive when a disc is inserted. If your disc drive is making a clicking noise or if your device fails to read the discs you insert, your disc drive may have stopped working. Use this guide to replace the disc drive in your laptop.
Qué necesitas
Partes
Herramientas
  1. Lenovo G500S Touch Disc Drive Replacement, Battery: paso 1, imagen 1 de 3 Lenovo G500S Touch Disc Drive Replacement, Battery: paso 1, imagen 2 de 3 Lenovo G500S Touch Disc Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure that your device is powered off and unplugged from the power source.
    • Flip your device over so that the back is facing you.
    • Using your fingers, push the tabs in opposite directions to eject the battery.
    • Remove the battery from the device.
  2. Lenovo G500S Touch Disc Drive Replacement, Back Panel: paso 2, imagen 1 de 2 Lenovo G500S Touch Disc Drive Replacement, Back Panel: paso 2, imagen 2 de 2
    • Remove the three 4mm screws on the back cover using the Phillips #00 screwdriver.
    • Remove the back cover from the device.
  3. Lenovo G500S Touch Disc Drive Replacement, Disc Drive: paso 3, imagen 1 de 3 Lenovo G500S Touch Disc Drive Replacement, Disc Drive: paso 3, imagen 2 de 3 Lenovo G500S Touch Disc Drive Replacement, Disc Drive: paso 3, imagen 3 de 3
    • Remove the single 6mm screw holding the disc drive in place using the same screwdriver.
    • Carefully pull out the disc drive and remove it from the device.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 986
