Saltar al contenido principal
Lenovo G50-70 Battery Replacement
Caleb DesJardins
Caleb DesJardins y 3 otros contribuidores
Última actualización: February 4, 2025
2 minuto
Muy fácil
Introducción
Ir al paso 1
If battery is not holding a charge for very long or laptop is not powering on without charger, the battery may need replacing. The battery is often the first component to go wrong on a laptop and luckily its very simple to replace. A defective battery shares symptoms with some other problems, but when these symptoms present, replacing the battery should be the first diagnosis because a new battery will always hold a charge longer than an old one.
Qué necesitas
  1. Lenovo G50-70 Battery Replacement, Battery: paso 1, imagen 1 de 3 Lenovo G50-70 Battery Replacement, Battery: paso 1, imagen 2 de 3 Lenovo G50-70 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Push the left switch (labeled 1) to the left to show red underneath. This will unlock battery.
    • Push the right switch (labeled 2) to the right. This will eject battery.
  2. Lenovo G50-70 Battery Replacement: paso 2, imagen 1 de 1
    • Rotate the battery away from the laptop.
Conclusión
Una persona más ha completado esta guía.
Un comentario
thanks the soluction my problem
server speed - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 35
Todo El Tiempo: 4,795
