Saltar al contenido principal
LG Stylo 2 Motherboard  Replacement
Devon Barber
Devon Barber y otro contribuidor
Última actualización: December 27, 2021
9 minuto
Fácil
Introducción
Ir al paso 1
When your phone becomes water damaged or any other internal damage comes to the motherboard it will become necessary to replace it. This guide will show you exactly how to do so with ease. When touching internal components make sure your hands are very clean or you are wearing gloves.
Qué necesitas
Herramientas
Ver más…
  1. LG Stylo 2 Motherboard  Replacement, Battery: paso 1, imagen 1 de 3 LG Stylo 2 Motherboard  Replacement, Battery: paso 1, imagen 2 de 3 LG Stylo 2 Motherboard  Replacement, Battery: paso 1, imagen 3 de 3
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. LG Stylo 2 Motherboard  Replacement: paso 2, imagen 1 de 3 LG Stylo 2 Motherboard  Replacement: paso 2, imagen 2 de 3 LG Stylo 2 Motherboard  Replacement: paso 2, imagen 3 de 3
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
  3. LG Stylo 2 Motherboard  Replacement, Rear Camera: paso 3, imagen 1 de 3 LG Stylo 2 Motherboard  Replacement, Rear Camera: paso 3, imagen 2 de 3 LG Stylo 2 Motherboard  Replacement, Rear Camera: paso 3, imagen 3 de 3
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
  4. LG Stylo 2 Motherboard  Replacement: paso 4, imagen 1 de 3 LG Stylo 2 Motherboard  Replacement: paso 4, imagen 2 de 3 LG Stylo 2 Motherboard  Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
  5. LG Stylo 2 Motherboard  Replacement, Motherboard: paso 5, imagen 1 de 3 LG Stylo 2 Motherboard  Replacement, Motherboard: paso 5, imagen 2 de 3 LG Stylo 2 Motherboard  Replacement, Motherboard: paso 5, imagen 3 de 3
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
Conclusión
Devon Barber
Miembro Desde 02/13/18
994 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S11-G1, Cheng Spring 2018 Miembro de USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
Miembros de 4
10 Guías creadas
1Guía Comentario
Charging retain 2.1
Kashif Kashi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 2,363
