Saltar al contenido principal
LG Optimus 3D Headphone Jack Replacement
Dale Pearson
Dale Pearson y 3 otros contribuidores
Última actualización: January 10, 2015
30 minuto
Moderado
Mejor introducción
Qué necesitas
Herramientas
Ver más…
  1. LG Optimus 3D Headphone Jack Replacement, Back Cover Removal: paso 1, imagen 1 de 2 LG Optimus 3D Headphone Jack Replacement, Back Cover Removal: paso 1, imagen 2 de 2
    • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
  2. LG Optimus 3D Headphone Jack Replacement, Battery Removal: paso 2, imagen 1 de 3 LG Optimus 3D Headphone Jack Replacement, Battery Removal: paso 2, imagen 2 de 3 LG Optimus 3D Headphone Jack Replacement, Battery Removal: paso 2, imagen 3 de 3
    • The battery is the large black rectangle towards the bottom half of the phone.
    • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
  3. LG Optimus 3D Headphone Jack Replacement, Screw Removal: paso 3, imagen 1 de 2 LG Optimus 3D Headphone Jack Replacement, Screw Removal: paso 3, imagen 2 de 2
    • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
    • 5.5mm length PH00 screws
    • 4mm length PH00 screws
  4. LG Optimus 3D Headphone Jack Replacement, Bottom Cover Removal: paso 4, imagen 1 de 2 LG Optimus 3D Headphone Jack Replacement, Bottom Cover Removal: paso 4, imagen 2 de 2
    • Gently pull down on the bottom cover to remove it.
  5. LG Optimus 3D Headphone Jack Replacement, Mid-Cover Bezel Removal: paso 5, imagen 1 de 3 LG Optimus 3D Headphone Jack Replacement, Mid-Cover Bezel Removal: paso 5, imagen 2 de 3 LG Optimus 3D Headphone Jack Replacement, Mid-Cover Bezel Removal: paso 5, imagen 3 de 3
    • Using a plastic opening tool, gently pry around the perimeter of the device.
    • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
    • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
  6. LG Optimus 3D Headphone Jack Replacement, Ribbon Cable Disconnection: paso 6, imagen 1 de 2 LG Optimus 3D Headphone Jack Replacement, Ribbon Cable Disconnection: paso 6, imagen 2 de 2
    • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
  7. LG Optimus 3D Headphone Jack Replacement, Adhesive Loosening: paso 7, imagen 1 de 1
    • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
    • Evenly heat the device in short intervals for about one minute.
    • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
  8. LG Optimus 3D Headphone Jack Replacement, SD/SIM Card Board Removal: paso 8, imagen 1 de 3 LG Optimus 3D Headphone Jack Replacement, SD/SIM Card Board Removal: paso 8, imagen 2 de 3 LG Optimus 3D Headphone Jack Replacement, SD/SIM Card Board Removal: paso 8, imagen 3 de 3
    • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
    • If the board is too difficult to separate than more heating may be required.
  9. LG Optimus 3D Headphone Jack Replacement, Disconnect Ribbon Cables: paso 9, imagen 1 de 2 LG Optimus 3D Headphone Jack Replacement, Disconnect Ribbon Cables: paso 9, imagen 2 de 2
    • Using a spudger or plastic opening tool, gently lift the ribbon cables connected to the motherboard.
    • The button tabs, highlighted in orange, are held in with a light adhesive. Gently lift them out of the body of the phone with a spudger.
  10. LG Optimus 3D Headphone Jack Replacement, Disconnect Antenna: paso 10, imagen 1 de 2 LG Optimus 3D Headphone Jack Replacement, Disconnect Antenna: paso 10, imagen 2 de 2
    • Remove the antenna cable by disconnecting both ends.
    • One end connects to the motherboard and the other connects near bottom of the phone.
  11. LG Optimus 3D Headphone Jack Replacement, Remove Motherboard: paso 11, imagen 1 de 2 LG Optimus 3D Headphone Jack Replacement, Remove Motherboard: paso 11, imagen 2 de 2
    • Using a spudger gently lift the motherboard assembly out of the case.
    • Make sure the motherboard does not get snagged on the camera's ribbon cable.
  12. LG Optimus 3D Headphone Jack Replacement, Ribbon Cable Disconnection: paso 12, imagen 1 de 1
    • Using the plastic opening tool disconnect the ribbon cable connected to the headphone jack assembly.
  13. LG Optimus 3D Headphone Jack Replacement, Headphone Jack Removal: paso 13, imagen 1 de 2 LG Optimus 3D Headphone Jack Replacement, Headphone Jack Removal: paso 13, imagen 2 de 2
    • Separate the Headphone Jack from the body of the phone. It should pop off relatively easily.
Conclusión
2 personas más completaron esta guía.
Dale Pearson
Miembro Desde 09/22/14
784 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 10-6, Brown Fall 2014 Miembro de USF Tampa, Team 10-6, Brown Fall 2014
USFT-BROWN-F14S10G6
Miembros de 3
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 540
