Saltar al contenido principal
LG K92 5G Screen Replacement
Taptic Digital
Taptic Digital y 2 otros contribuidores
Última actualización: May 7, 2024
20 minuto
Moderado
Guía aportada por comunidad
Introducción
Ir al paso 1
This guide shows how to disassemble and transfer the internal components of a LG K92 to a replacement display with a frame preinstalled. The parts used are a replacement screen installed into a frame, this is the most cost effective method, using just the display without a frame is not advised.
Resumen del Video
  1. LG K92 5G Screen Replacement, Removing the Back Panel: paso 1, imagen 1 de 1
    • Heat the plastic back panel with a heatgun or heating pad.
    • Use a thin metal pry tool or razor to separate the adhesive from the frame, and peel the back cover off.
  2. LG K92 5G Screen Replacement, Remove antenna board and screws: paso 2, imagen 1 de 2 LG K92 5G Screen Replacement, Remove antenna board and screws: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Remove 11 same-sized phillips screws from the top antenna panel.
    • Using tweezers, forcefully pop the panel from a safe area up and out of the housing, the lower middle screw hole is a good area to apply leverage.
  3. LG K92 5G Screen Replacement, Remove lower speaker and screws: paso 3, imagen 1 de 2 LG K92 5G Screen Replacement, Remove lower speaker and screws: paso 3, imagen 2 de 2
    • Remove 8 more identically sized phillips screws from the lower antenna and speaker panel.
    • Pop the lower panel off with tweezers, it should come off relatively easier than the previous panel.
  4. LG K92 5G Screen Replacement, Disconnect almost everything: paso 4, imagen 1 de 1
    • Disconnect the battery first!
    • Then disconnect the other main lego style connectors and ribbons. There is no need to disconnect the cameras.
  5. LG K92 5G Screen Replacement, Pull the main logic board out: paso 5, imagen 1 de 1
    • Remove the main logic board by pulling from the top and lifting it out.
  6. LG K92 5G Screen Replacement, Remove charging port board: paso 6, imagen 1 de 1
    • Remove the single Phillips screw from the charging daughterboard, and pull it out of the frame.
    • (Optional) Leave the antenna lines connected to reduce risk of breaking them.
  7. LG K92 5G Screen Replacement, Extract the power button/fingerprint reader: paso 7, imagen 1 de 2 LG K92 5G Screen Replacement, Extract the power button/fingerprint reader: paso 7, imagen 2 de 2
    • The power button has a small pressure connected ribbon that is adhered to the frame, carefully pry it up.
    • The fingerprint reader itself is on a separate lego style connector that can then be fished out.
  8. LG K92 5G Screen Replacement, Remove volume and quick button flex: paso 8, imagen 1 de 1
    • Gently pull the pressure connection pad up from the frame, then work the ribbon out from the trench.
  9. LG K92 5G Screen Replacement, Extract Volume and Quick Action keys: paso 9, imagen 1 de 1
    • Using tweezers or a bent pry tool, push the buttons out from inside of the frame.
  10. LG K92 5G Screen Replacement, Remove small components: paso 10, imagen 1 de 1
    • Some small components like the vibration motor, antenna sticker, or earspeaker may need to be moved to the new frame.
  11. LG K92 5G Screen Replacement, Battery removal: paso 11, imagen 1 de 1
    • Use a heating pad to warm the device from the front, apply generous amounts of alcohol to the battery compartment and carefully lift it out.
    • Avoid bending the battery as this can compromise the internal cells.
  12. LG K92 5G Screen Replacement, Install components in the replacement frame: paso 12, imagen 1 de 2 LG K92 5G Screen Replacement, Install components in the replacement frame: paso 12, imagen 2 de 2
    • Remove protective plastics from the replacement frame.
    • Reinstall components in the order in which they were removed. Be sure to align the antenna wires carefully to prevent pinching issues.
  13. LG K92 5G Screen Replacement, Finish it up!: paso 13, imagen 1 de 1
    • Reinstall remaining components and tighten screws in their respective locations.
    • Always test the device prior to sealing the back panel on with new adhesive.
Conclusión
Taptic Digital
Miembro Desde 03/24/22
226 Reputación
1 Guía escrita
4Guía Comentarios
Why is there no reassembly guide?
Zach Benson - Contestar
Follow the steps in reverse order.
Taptic Digital -
What is the black item adhered on top of the battery, with the connector!
JS1 - Contestar
NFC coil, it is not a wireless charging coil despite being similar in appearance.
Taptic Digital -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 14
Ultimos 30 días: 66
Todo El Tiempo: 2,109
