Saltar al contenido principal
LG K7 T-Mobile Motherboard Replacement
Brandon Jones
Brandon Jones y 2 otros contribuidores
Última actualización: December 10, 2021
30 minuto
Moderado
Introducción
Ir al paso 1
This is guide will demonstrate how to remove the motherboard from a LG-K7. The motherboard has numerous of components connecting to it and user should be careful while removing these component so the main board doesn't get damage.
Qué necesitas
Partes
Herramientas
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #00 Screwdriver
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. LG K7 T-Mobile Motherboard Replacement, Battery: paso 1, imagen 1 de 2 LG K7 T-Mobile Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
  2. LG K7 T-Mobile Motherboard Replacement: paso 2, imagen 1 de 1
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
  3. LG K7 T-Mobile Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the battery.
  4. LG K7 T-Mobile Motherboard Replacement, Motherboard: paso 4, imagen 1 de 2 LG K7 T-Mobile Motherboard Replacement, Motherboard: paso 4, imagen 2 de 2
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
  5. LG K7 T-Mobile Motherboard Replacement: paso 5, imagen 1 de 3 LG K7 T-Mobile Motherboard Replacement: paso 5, imagen 2 de 3 LG K7 T-Mobile Motherboard Replacement: paso 5, imagen 3 de 3
    • Turn the phone over so the screen is facing up.
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
  6. LG K7 T-Mobile Motherboard Replacement: paso 6, imagen 1 de 3 LG K7 T-Mobile Motherboard Replacement: paso 6, imagen 2 de 3 LG K7 T-Mobile Motherboard Replacement: paso 6, imagen 3 de 3
    • Locate the lock that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
  7. LG K7 T-Mobile Motherboard Replacement: paso 7, imagen 1 de 2 LG K7 T-Mobile Motherboard Replacement: paso 7, imagen 2 de 2
    • Locate the headphone jack towards the bottom right of the phone.
    • Place a plastic removal tool underneath the head phone jack.
    • Lift the plastic removal tool upward to remove the earphone jack from the phone case.
  8. LG K7 T-Mobile Motherboard Replacement: paso 8, imagen 1 de 2 LG K7 T-Mobile Motherboard Replacement: paso 8, imagen 2 de 2
    • Locate the ribbon for the front facing camera.
    • Carefully remove the front facing camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the front camera ribbon you just released pull upwards and the camera should release from the case.
    • Remove the band that connects the screen display to the motherboard.
  9. LG K7 T-Mobile Motherboard Replacement: paso 9, imagen 1 de 2 LG K7 T-Mobile Motherboard Replacement: paso 9, imagen 2 de 2
    • Locate the ribbon cable that connects the screen to the motherboard.
    • Carefully remove the screen's ribbon cable from the motherboard using the plastic removal tool by lifting the ribbon cable upwards.
  10. LG K7 T-Mobile Motherboard Replacement: paso 10, imagen 1 de 3 LG K7 T-Mobile Motherboard Replacement: paso 10, imagen 2 de 3 LG K7 T-Mobile Motherboard Replacement: paso 10, imagen 3 de 3
    • Wedge a plastic opening tool between the motherboard and the phones casing.
    • While using one finger to hold down a portion of the phone pull upwards with the plastic opening tool to loosen the motherboard from the phone casing.
    • Once there is some space between the board and the phone case, using your hands carefully lift the motherboard from the phone casing.
Conclusión
7 personas más completaron esta guía.
Brandon Jones
Miembro Desde 09/28/17
233 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S2-G5, Nance Fall 2017 Miembro de USF Tampa, Team S2-G5, Nance Fall 2017
USFT-NANCE-F17S2G5
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 2,227
