Saltar al contenido principal
LG G3 Screen flicker and fades
albanjakupi
albanjakupi y 2 otros contribuidores
Última actualización: October 16, 2020
10 - 25 minutos
Moderado
Guía aportada por comunidad
Introducción
Ir al paso 1
  1. Remove the battery.
  2. Unfasten all screws and remove the plastic cover.
  3. You will see connectors next to the charging port. Disconnect them and you can blow some air to take the dirt off.
  4. Take some paper and fold it 4 to 6 times (small one).
  5. After folding it make sure it is the size of the connector that is next to the Camera.
  6. Place the folded paper on top of the connector.
  7. Slowly get back all the plastic covers.
  8. Put all screws back in and fasten them.
  9. Place the battery, SD Card and the Sim back.
  10. Power on the Phone.
99.9% It will work.
UPDATE:
If you want to take it a step further, get some thermal paste and remove the whole circuit board and put some on the spot (as shown in the picture) do NOT put too much a dot will be enough...
after that, you can go ahead and place the circuit board back in place, then place the paper on the connector(follow the steps 6-10)
*Even thermal pad might do the job.
Thanks,
I hope this will fix the problem !
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. LG G3 Screen flicker and fades, Place The Folden Paper Here!: paso 1, imagen 1 de 1
    • Place The Paper Here On this Connector!
  2. LG G3 Screen flicker and fades, Thermal Paste: paso 2, imagen 1 de 1
    • A small dot will do the job better than overfilling !
Conclusión
It is not to Hard to perform this Fix.
Just don't touch anything else and be careful while taking the plastic cover off....
Everything is going to be fine.
60 personas más completaron esta guía.
albanjakupi
Miembro Desde 02/15/17
1,813 Reputación
1 Guía escrita
57 comentarios
Shume mire !! A ke Informacion si po ndrohet " Displayglass", jo krejt Display, po vetem ajo Pjesa e pare.
Tfala Bekim Jakupi
Bekim Jakupi - Contestar
I am not sure who this is going to but I wanted to know about the repair of the flickering and fading screen of the LG G3. Is that procedure a long term fix and what causes the symptoms. Also is the little piece of paper any type of fire hazard. The repair worked and it blows my mind. Thank you so much. I brought my phone to a repair shop and they were unable to fix it, Thank you again. If you wish to respond to me. My name is rich and my E-MAIL address is raidernation61@sbcglobal.net.
raidernation61 - Contestar
do you have a gmail ? i want ask about this lg g3 problem . ty
wawan D -
I don't know why, but this works! Thank You!
dlinsc - Contestar
Absolutely worked. Thanks for this. The flex cable just need to be push hard to the socket.
Ronald Tariga - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 42
Todo El Tiempo: 63,032
