Saltar al contenido principal
LG G Vista Charging Dock Replacement
Key Baker
Key Baker y 4 otros contribuidores
Última actualización: May 7, 2024
7 - 10 minutos
Moderado
Introducción
Ir al paso 1
This guide will teach you how to replace the charging dock in your LG G Vista. In this guide you will need tweezers, and a spudger.
Qué necesitas
Herramientas
Ver más…
  1. LG G Vista Charging Dock Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the device is powered off.
  2. LG G Vista Charging Dock Replacement: paso 2, imagen 1 de 1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Charging Dock Replacement: paso 3, imagen 1 de 1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Charging Dock Replacement, Charging Dock: paso 4, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the eleven 3.0 mm screws around the perimeter of the phone.
  5. LG G Vista Charging Dock Replacement: paso 5, imagen 1 de 1
    • Use a plastic spudger, or finger nail, to lift up the hard shell on the top of the phone.
  6. LG G Vista Charging Dock Replacement: paso 6, imagen 1 de 2 LG G Vista Charging Dock Replacement: paso 6, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the five 3.0 mm screws.
    • Remove the bottom hard shell from the device.
  7. LG G Vista Charging Dock Replacement: paso 7, imagen 1 de 2 LG G Vista Charging Dock Replacement: paso 7, imagen 2 de 2
    • Using a Phillips #000 screwdriver, remove the two screws from the device.
  8. LG G Vista Charging Dock Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using a pair of tweezers, lift up the two antennas surrounding the battery.
  9. LG G Vista Charging Dock Replacement: paso 9, imagen 1 de 1
    • Disconnect the two connectors on the right side of the charging port.
  10. LG G Vista Charging Dock Replacement: paso 10, imagen 1 de 1
    • Lift up the charging port with the plastic opening tool.
    • Remove the charging port from the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 696
