Saltar al contenido principal
LG Enact Camera Replacement
pranay_munikuntla
pranay_munikuntla y 5 otros contribuidores
Última actualización: May 7, 2024
20 minuto
Moderado
Introducción
Ir al paso 1
A camera in a device captures moments and memories, but with extensive use, the camera component may encounter issues or stop functioning properly. If you've noticed blurry images, black screens, or error messages when trying to access your camera, it could indicate a problem with the camera module itself.
In this guide, we'll walk you through the steps to safely remove and replace the camera in the LG Enact. This guide will help you address potential camera-related issues. Remember to power off your device before starting the camera replacement process to ensure a safe and effective procedure.
Qué necesitas
Herramientas
Ver más…
  1. LG Enact Camera Replacement, Battery: paso 1, imagen 1 de 3 LG Enact Camera Replacement, Battery: paso 1, imagen 2 de 3 LG Enact Camera Replacement, Battery: paso 1, imagen 3 de 3
    • Open the back cover by prying into the bottom tab with an iFixit opening tool.
  2. LG Enact Camera Replacement: paso 2, imagen 1 de 3 LG Enact Camera Replacement: paso 2, imagen 2 de 3 LG Enact Camera Replacement: paso 2, imagen 3 de 3
    • Use an iFixit opening tool to remove the battery.
  3. LG Enact Camera Replacement, Speaker: paso 3, imagen 1 de 1
    • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
  4. LG Enact Camera Replacement: paso 4, imagen 1 de 2 LG Enact Camera Replacement: paso 4, imagen 2 de 2
    • Use an iFixit opening pick to pop out the speaker.
  5. LG Enact Camera Replacement, Midframe: paso 5, imagen 1 de 2 LG Enact Camera Replacement, Midframe: paso 5, imagen 2 de 2
    • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
  6. LG Enact Camera Replacement: paso 6, imagen 1 de 1
    • Use the iFixit opening pick to pry out the midframe.
  7. LG Enact Camera Replacement, Camera: paso 7, imagen 1 de 1
    • Slowly, pop the camera lens out of the socket.
  8. LG Enact Camera Replacement: paso 8, imagen 1 de 2 LG Enact Camera Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Using tweezers, remove the camera assembly connector.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 80
