Saltar al contenido principal
LG Chocolate Sliding Mechanism Replacement
Thomas
Thomas y 6 otros contribuidores
Última actualización: January 17, 2025
Sin estimación
Moderado
Necesita mejores imágenes
Estudiante en Progreso
¡Viñetas!
Error de marcado
Fotos de acción
Mejor introducción
Faltan Detalles
Qué necesitas
Herramientas
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Ver más…
  1. LG Chocolate Sliding Mechanism Replacement, Battery: paso 1, imagen 1 de 2 LG Chocolate Sliding Mechanism Replacement, Battery: paso 1, imagen 2 de 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Sliding Mechanism Replacement, Back Cover: paso 2, imagen 1 de 1
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate Sliding Mechanism Replacement: paso 3, imagen 1 de 3 LG Chocolate Sliding Mechanism Replacement: paso 3, imagen 2 de 3 LG Chocolate Sliding Mechanism Replacement: paso 3, imagen 3 de 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case
  4. LG Chocolate Sliding Mechanism Replacement, Sliding Front: paso 4, imagen 1 de 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Sliding Mechanism Replacement: paso 5, imagen 1 de 2 LG Chocolate Sliding Mechanism Replacement: paso 5, imagen 2 de 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Sliding Mechanism Replacement: paso 6, imagen 1 de 2 LG Chocolate Sliding Mechanism Replacement: paso 6, imagen 2 de 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Sliding Mechanism Replacement: paso 7, imagen 1 de 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Sliding Mechanism Replacement, Sliding Mechanism: paso 8, imagen 1 de 1
    • Use a Phillips #00 to remove the 4 screws that hold the sliding mechanism in place.
  9. LG Chocolate Sliding Mechanism Replacement: paso 9, imagen 1 de 1
    • Remove sliding mechanism.
Conclusión
Una persona más ha completado esta guía.
Thomas
Miembro Desde 01/18/13
91 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 19-46, Regan Winter 2013 Miembro de Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
Miembros de 4
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 398
