Kodak EasyShare LS743 Battery Door Replacement
Introducción
Ir al paso 1This is a step-by-step guide in replacing the battery door
Qué necesitas
Herramientas
Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
Remove the metal piece holding down the lanyard, then remove the lanyard.
Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
One 6.25 mm screw is located on the top right corner, right to the "OK" button.
Four 4.45 mm screws are on the bottom of the camera.
Two 2.95 mm screws are on the left side of the camera, above the USB port.
Una persona más ha completado esta guía.
