Saltar al contenido principal
JVC GR-D72U Lateral Function Port Panel Replacement
Qué necesitas
  1. JVC GR-D72U Lateral Function Port Panel Replacement, Battery: paso 1, imagen 1 de 2 JVC GR-D72U Lateral Function Port Panel Replacement, Battery: paso 1, imagen 2 de 2
    • Locate button on bottom of camera.
    • Slide button to the right.
  2. JVC GR-D72U Lateral Function Port Panel Replacement: paso 2, imagen 1 de 1
    • Pull the battery towards the bottom of the camcorder while lifting battery .
  3. JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: paso 3, imagen 1 de 3 JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: paso 3, imagen 2 de 3 JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: paso 3, imagen 3 de 3
    • Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
    • Remove the 3.1 mm screw.
    • Remove the three 5.3 mm screws from the back of the camera.
  4. JVC GR-D72U Lateral Function Port Panel Replacement: paso 4, imagen 1 de 1
    • From the bottom of the camera remove the following four screws:
    • 5.3 mm
    • 3.1 mm
    • 5.1 mm
    • 3.5 mm
  5. JVC GR-D72U Lateral Function Port Panel Replacement: paso 5, imagen 1 de 1
    • Use the small plastic opening tool to remove the blue side cover piece.
  6. JVC GR-D72U Lateral Function Port Panel Replacement: paso 6, imagen 1 de 1
    • Remove the 3.1 mm screw on top of the camera, closest to the LCD monitor.
    • Remove the 5.4 mm screw next to the snapshot button.
  7. JVC GR-D72U Lateral Function Port Panel Replacement: paso 7, imagen 1 de 1
    • Remove the 3.1 mm screw next to the USB and DV inputs.
  8. JVC GR-D72U Lateral Function Port Panel Replacement: paso 8, imagen 1 de 1
    • Gently pull apart both halves of the camera to reveal the inner components.
  9. JVC GR-D72U Lateral Function Port Panel Replacement: paso 9, imagen 1 de 3 JVC GR-D72U Lateral Function Port Panel Replacement: paso 9, imagen 2 de 3 JVC GR-D72U Lateral Function Port Panel Replacement: paso 9, imagen 3 de 3
    • Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
    • Insert the cables from the new port panel into their inputs and flip the locks to the down position.
    • It is easier to use tweezers when inserting the cable but not required.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team S2-G2, Nance Fall 2017 Miembro de USF Tampa, Team S2-G2, Nance Fall 2017
USFT-NANCE-F17S2G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 386
