Saltar al contenido principal
Infinity v2 10.1 Speakers Replacement
Nate Rice
Nate Rice y 6 otros contribuidores
Última actualización: May 7, 2024
15 - 20 minutos
Moderado
Introducción
Ir al paso 1
You may have to replace the Infinity v2 10.1 speakers if the device no longer makes sound or the sound is muffled or distorted. When removing the speaker, a soldering iron is required. Make sure to follow all the safety warnings and instructions in this guide and in the instructions of your soldering iron.
Warning: When using this guide, follow all the safety warnings and instructions related to soldering to avoid injury.
Qué necesitas
Herramientas
Ver más…
  1. Infinity v2 10.1 Speakers Replacement, Back Case: paso 1, imagen 1 de 3 Infinity v2 10.1 Speakers Replacement, Back Case: paso 1, imagen 2 de 3 Infinity v2 10.1 Speakers Replacement, Back Case: paso 1, imagen 3 de 3
    • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
    • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
    • There will be a slight click noise as you free each tab.
    • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
  2. Infinity v2 10.1 Speakers Replacement: paso 2, imagen 1 de 2 Infinity v2 10.1 Speakers Replacement: paso 2, imagen 2 de 2
    • Remove the speakers from the case by gently lifting them up and out of their slots.
  3. Infinity v2 10.1 Speakers Replacement, Speakers: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Turn on your soldering iron and allow it to heat up. Once it is hot, press the tip of the iron to the both of the solder points that attach the wires to the motherboard until the solder is melted.
    • Once the solder is melted, use tweezers to remove the wires from the motherboard.
    • The solder and iron will be extremely hot. You can use tweezers to grab the wire to avoid burning your fingers from accidental contact with the iron.
Conclusión
Nate Rice
Miembro Desde 10/31/19
321 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 159
