InFocus IN3104 Speaker Replacement
Introducción
Ir al paso 1The Infocus IN3104 has two speakers installed. If you can’t hear any sound playing from the device or sound is only coming from one side, you will have to replace one or both of the speakers. For this guide, you need a Philips # 1 screwdriver head. This task does not need any special skills to complete.
Qué necesitas
Turn the projector so that the lens is facing you.
Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
Remove the service cover.
Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
Lift up the metal cover and set it aside to reveal the motherboard.
Unplug the speaker wire that is located right behind the cooling fan.
Use a Phillips #1 screwdriver to remove the two 6 mm screws on the frame brackets.
