Saltar al contenido principal
IKEA Underverk Knob Replacement
Christian
Christian y 2 otros contribuidores
Última actualización: June 26, 2024
30 segundo
Muy fácil
Guía aportada por comunidad
  1. IKEA Underverk Knob Replacement, The broken knob: paso 1, imagen 1 de 2 IKEA Underverk Knob Replacement, The broken knob: paso 1, imagen 2 de 2
    • After two years the knob broke.
    • I tried to glue it together using JB Weld. It did not work. After I re-installed the knob and turned it for the first time, it just broke again.
    • IKEA is no help. On the other hand they praise their engagement for the environment, on the other hand they don't supply any spare parts.
  2. IKEA Underverk Knob Replacement, Use another knob: paso 2, imagen 1 de 3 IKEA Underverk Knob Replacement, Use another knob: paso 2, imagen 2 de 3 IKEA Underverk Knob Replacement, Use another knob: paso 2, imagen 3 de 3
    • So I just tried a knob I had laying around for my synthesizers and it worked perfect! The outer diameter is a bit small, so maybe order a bigger outer diameter.
    • The inner diameter is 6mm and a part of the shaft is flat.
    • As an example I have put a link to a (german) distributor in this instruction. The order number is KNOPF 13-164B, the distributor is reichelt.de.
Conclusión
Una persona más ha completado esta guía.
Christian
Miembro Desde 03/09/14
1,625 Reputación
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 22
Ultimos 30 días: 125
Todo El Tiempo: 2,979
