Saltar al contenido principal
Huawei MediaPad M3 Battery Replacement
Jackson Bridges
Jackson Bridges y 2 otros contribuidores
Última actualización: October 24, 2024
15 minuto
Moderado
Introducción
Ir al paso 1
If your Huawei MultiPad M3 (model 9599773) is not providing sufficient battery life or taking too long to charge, use this guide to replace the battery in the tablet. Before deciding to replace the battery, inspect the charging chord for damage or a short in the wiring causing the device not to charge properly. Typically, a new chord will give the device sufficient battery life.
Before beginning make sure to power off your phone completely and disconnect from any external power.
Qué necesitas
Herramientas
Ver más…
  1. Huawei MediaPad M3 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Using the Jimmy tool, gently pry the display open.
    • Wear ESD bracelet to ensure you are electrostatic safe.
  2. Huawei MediaPad M3 Battery Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the six 3.0mm screws.
  3. Huawei MediaPad M3 Battery Replacement: paso 3, imagen 1 de 1
    • Using the tweezer tool, remove the ribbon cable attached to the main display in two places.
  4. Huawei MediaPad M3 Battery Replacement: paso 4, imagen 1 de 3 Huawei MediaPad M3 Battery Replacement: paso 4, imagen 2 de 3 Huawei MediaPad M3 Battery Replacement: paso 4, imagen 3 de 3
    • Using the tweezer tool, remove the three remaining ribbon cables.
  5. Huawei MediaPad M3 Battery Replacement: paso 5, imagen 1 de 1
    • Using the Jimmy, break the adhesive that holds the battery to the main body and remove the battery from the device.
Conclusión
7 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 53
Ultimos 30 días: 137
Todo El Tiempo: 7,036
