How to adjust Triace A310 Brake Cable
10 - 15 minutos
Fácil
Introducción
Ir al paso 1If your brakes are slowing you down too fast or not fast enough, this guide can help remedy this problem.
Qué necesitas
While holding onto the brake cable, unscrew the screw that holds the brake cable in place using a 5mm allen wrench.
Casi Terminas!
You may need to repeat this process until your desired tension is achieved (trial and error).
Conclusión
