Saltar al contenido principal
How to Resolder the LEDs on a Seville Classics MSC10166
Queena Phung
Queena Phung y 8 otros contribuidores
Última actualización: June 11, 2021
10 minuto
Moderado
Fotos de acción
Necesita mejores imágenes
Introducción
Ir al paso 1
This guide will show you how to get to the LEDs on your Seville Classics MSC10166 Tower Fan and how to inspect the circuit board. If there is a faulty connection or a loose wire, this guide demonstrates a quick solution.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. How to Resolder the LEDs on a Seville Classics MSC10166, PCB (Printed Circuit Board): paso 1, imagen 1 de 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. How to Resolder the LEDs on a Seville Classics MSC10166: paso 2, imagen 1 de 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. How to Resolder the LEDs on a Seville Classics MSC10166: paso 3, imagen 1 de 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. How to Resolder the LEDs on a Seville Classics MSC10166: paso 4, imagen 1 de 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. How to Resolder the LEDs on a Seville Classics MSC10166: paso 5, imagen 1 de 2 How to Resolder the LEDs on a Seville Classics MSC10166: paso 5, imagen 2 de 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. How to Resolder the LEDs on a Seville Classics MSC10166, How to Resolder the LEDs on a Seville Classics MSC10166: paso 6, imagen 1 de 1
    • Shown is the top side of the printed circuit board that contains the LEDs.
    • Inspect the PCB for any faulty connections or loose components.
  7. How to Resolder the LEDs on a Seville Classics MSC10166: paso 7, imagen 1 de 3 How to Resolder the LEDs on a Seville Classics MSC10166: paso 7, imagen 2 de 3 How to Resolder the LEDs on a Seville Classics MSC10166: paso 7, imagen 3 de 3
    • Make sure the wires on the side of the board are properly connected.
    • If the wires have are not connected properly, re-solder them to the board using the soldering iron.
Conclusión
Una persona más ha completado esta guía.
Queena Phung
Miembro Desde 09/26/12
114 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 15-46, Forte Fall 2012 Miembro de Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Miembros
6 Guías creadas
4 comentarios
Good stuff except for the fact that the most common problem(fan not working) that is for me, the first and simplest repair listed is referred to a dead end in led repair section. I could be wrong, but still, where is the fuse and how does the ohm meter work for a fuse test again? Hey, your fixer guide is the one that brought it up in the first place. Just saying.....
Finner 69 - Contestar
Agreed with Finner 69, that where is the fuse and how does the ohm meter work for a fuse test again? I have Seville Ultraslimline tower fan and fan not working. Power there.
Ava - Contestar
Did you fix your fan? The fuse is on the printed circuit board with the LEDs. Set your multimeter to ohms. Touch the red lead to one side of the fuse and the black to the other. If the fuse is good, the reading should go to zero or near zero. If it's blown, it will stay at one. Mine was good, so I have to continue looking for the problem.
edtrembickiguy -
For me, all of the wires weren’t connected into the motor of the fan, so maybe check that.
Thomas Cunningham - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 33
Todo El Tiempo: 8,582
