Saltar al contenido principal
How to Replace The Bottom Shower Door Seal
Omar Escobedo
Omar Escobedo y otro contribuidor
Última actualización: December 22, 2023
10 - 30 minutos
Fácil
Introducción
Ir al paso 1
This step-by-step guide shows how to replace the shower door seal found at the bottom of the shower door. Generally speaking, the shower door seal strip should be replaced every 1-2 years; however, also consider replacing it if it is torn, cracked, or too dirty.
  1. How to Replace The Bottom Shower Door Seal, Shower Door Seal: paso 1, imagen 1 de 2 How to Replace The Bottom Shower Door Seal, Shower Door Seal: paso 1, imagen 2 de 2
    • Remove the old shower door seal by sliding it off the door.
  2. How to Replace The Bottom Shower Door Seal: paso 2, imagen 1 de 2 How to Replace The Bottom Shower Door Seal: paso 2, imagen 2 de 2
    • Clean the area where the old seal was at the bottom of the shower door.
  3. How to Replace The Bottom Shower Door Seal: paso 3, imagen 1 de 1
    • Measure the old shower door seal.
  4. How to Replace The Bottom Shower Door Seal: paso 4, imagen 1 de 1
    • Mark how long the new shower door seal should be per the previous measurement.
  5. How to Replace The Bottom Shower Door Seal: paso 5, imagen 1 de 1
    • Cut the new shower door seal on the mark placed in the previous step.
    • Use whichever cutting tool is available that can cut this material.
  6. How to Replace The Bottom Shower Door Seal: paso 6, imagen 1 de 1
    • Sand/Smooth Off the side of the seal that was cut in previous step.
  7. How to Replace The Bottom Shower Door Seal: paso 7, imagen 1 de 3 How to Replace The Bottom Shower Door Seal: paso 7, imagen 2 de 3 How to Replace The Bottom Shower Door Seal: paso 7, imagen 3 de 3
    • Slide the new seal on with the deflector facing the inside of the shower.
Conclusión
Omar Escobedo
Miembro Desde 10/23/23
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 68
Todo El Tiempo: 1,681
