Saltar al contenido principal
How to Remove Stains From a Porcelain Sink
Nishtha Malhotra
Nishtha Malhotra y 2 otros contribuidores
Última actualización: January 12, 2023
15 minuto
Fácil
Introducción
Ir al paso 1
Porcelain sinks are a beautiful addition to our kitchens and bathrooms but they tend to get stains overtime. These stains are removable using the right procedure however wrong methods can leave them permanently scratched or damaged. This guide will showcase step-by-step process to remove surface stains and how to keep your sink stain and odour free.
  1. How to Remove Stains From a Porcelain Sink, How to Remove Stains From a Porcelain Sink: paso 1, imagen 1 de 2 How to Remove Stains From a Porcelain Sink, How to Remove Stains From a Porcelain Sink: paso 1, imagen 2 de 2
    • Sprinkle water on the sink and use a paper towel to wipe the sink.
    • The sink needs to be a little damp before starting the process so make sure you do not dry it completely.
  2. How to Remove Stains From a Porcelain Sink: paso 2, imagen 1 de 2 How to Remove Stains From a Porcelain Sink: paso 2, imagen 2 de 2
    • Wear a pair of Vinyl or your cleaning gloves and then sprinkle the baking soda on the damp sink.
    • It is recommended to use a bowl for baking soda. If you use the box directly, you can accidentally drop too much baking soda on the sink.
  3. How to Remove Stains From a Porcelain Sink: paso 3, imagen 1 de 2 How to Remove Stains From a Porcelain Sink: paso 3, imagen 2 de 2
    • Take a wet sponge and use it to scrub the sink in circular motions. Scrub the harder stains with slightly more force.
    • Make sure you squeeze the sponge beforehand to take out excess water so it is easier to scrub.
  4. How to Remove Stains From a Porcelain Sink: paso 4, imagen 1 de 1
    • Wait for 2 minutes and then spray hydrogen peroxide over the sink.
    • If you cannot find hydrogen peroxide then you can also use liquid oxygen bleach as a substitute.
  5. How to Remove Stains From a Porcelain Sink: paso 5, imagen 1 de 1
    • Scrub again for another 2-3 minutes. Try to scrub the hard stains with a little force.
  6. How to Remove Stains From a Porcelain Sink: paso 6, imagen 1 de 3 How to Remove Stains From a Porcelain Sink: paso 6, imagen 2 de 3 How to Remove Stains From a Porcelain Sink: paso 6, imagen 3 de 3
    • Take half a lime/lemon and dip it in baking soda and then use it to clean any leftover rust stains.
    • Scrub for 2-3 minutes.
    • This step will also remove the peroxide/bleach smell.
  7. How to Remove Stains From a Porcelain Sink: paso 7, imagen 1 de 2 How to Remove Stains From a Porcelain Sink: paso 7, imagen 2 de 2
    • Turn the tap on and use the sponge to wipe any leftover stains and residue from baking soda or lemon.
Conclusión
The steps in this guide can be repeated often on the sink in order to avoid any lasting stains.
Una persona más ha completado esta guía.
Nishtha Malhotra
Miembro Desde 01/17/21
175 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 67
Todo El Tiempo: 2,804
