Saltar al contenido principal
How to Install Handlebar Tape
Elizabeth Hall
Elizabeth Hall y 3 otros contribuidores
Última actualización: July 25, 2017
25 - 35 minutos
Moderado
Introducción
Ir al paso 1
This guide will demonstrate how to wrap handlebar tape on a road bike with dropout-style handlebars.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. How to Install Handlebar Tape, How to Install Handlebar Tape: paso 1, imagen 1 de 2 How to Install Handlebar Tape, How to Install Handlebar Tape: paso 1, imagen 2 de 2
    • Flip the hood of the brake lever upwards.
  2. How to Install Handlebar Tape: paso 2, imagen 1 de 3 How to Install Handlebar Tape: paso 2, imagen 2 de 3 How to Install Handlebar Tape: paso 2, imagen 3 de 3
    • Peel off the adhesive covering from the back of the bar tape.
    • Place one end of the bar tape around the handlebar, making sure to leave a half inch extended past the end of the handlebar.
    • Begin tightly wrapping the bar tape clockwise around the handlebar so that the bar tape overlaps itself slightly.
  3. How to Install Handlebar Tape: paso 3, imagen 1 de 2 How to Install Handlebar Tape: paso 3, imagen 2 de 2
    • After a few wraps, tuck the extra bar tape into the end of the handlebar and firmly push in the bar end plug.
  4. How to Install Handlebar Tape: paso 4, imagen 1 de 2 How to Install Handlebar Tape: paso 4, imagen 2 de 2
    • Continue to tightly wrap the bar tape around the bar as evenly as possible.
    • Make sure the adhesive on the back of the bar tape is making contact with the metal handlebar.
  5. How to Install Handlebar Tape: paso 5, imagen 1 de 3 How to Install Handlebar Tape: paso 5, imagen 2 de 3 How to Install Handlebar Tape: paso 5, imagen 3 de 3
    • Take the extra piece of bar tape provided and cut it to fit the back of the brake lever.
  6. How to Install Handlebar Tape: paso 6, imagen 1 de 3 How to Install Handlebar Tape: paso 6, imagen 2 de 3 How to Install Handlebar Tape: paso 6, imagen 3 de 3
    • Continue wrapping over lever.
    • Keep in mind the tightness and evenness of space between each wrap as you continue.
  7. How to Install Handlebar Tape: paso 7, imagen 1 de 2 How to Install Handlebar Tape: paso 7, imagen 2 de 2
    • Flip the break lever hood back down and continue.
  8. How to Install Handlebar Tape: paso 8, imagen 1 de 2 How to Install Handlebar Tape: paso 8, imagen 2 de 2
    • Stop wrapping about 2 inches from stem.
  9. How to Install Handlebar Tape: paso 9, imagen 1 de 3 How to Install Handlebar Tape: paso 9, imagen 2 de 3 How to Install Handlebar Tape: paso 9, imagen 3 de 3
    • Cut the bar tape diagonally at an approximately 60 degree angle.
  10. How to Install Handlebar Tape: paso 10, imagen 1 de 1
    • Finish the wrap.
    • The cut should make the end of the bar tape a straight line.
  11. How to Install Handlebar Tape: paso 11, imagen 1 de 3 How to Install Handlebar Tape: paso 11, imagen 2 de 3 How to Install Handlebar Tape: paso 11, imagen 3 de 3
    • Use the electrical tape provided to tightly secure the end of the wrap.
  12. How to Install Handlebar Tape: paso 12, imagen 1 de 3 How to Install Handlebar Tape: paso 12, imagen 2 de 3 How to Install Handlebar Tape: paso 12, imagen 3 de 3
    • Press down on electrical tape to secure it.
  13. How to Install Handlebar Tape: paso 13, imagen 1 de 3 How to Install Handlebar Tape: paso 13, imagen 2 de 3 How to Install Handlebar Tape: paso 13, imagen 3 de 3
    • Repeat steps 1-12 on the other side, now wrapping counterclockwise.
Linea de Meta
Una persona más ha completado esta guía.
Elizabeth Hall
Miembro Desde 04/28/17
131 Reputación
1 Guía escrita
Equipo
UC Davis, Team S2-G7, Cole Spring 2017 Miembro de UC Davis, Team S2-G7, Cole Spring 2017
UCD-COLE-S17S2G7
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 20
Todo El Tiempo: 4,106
