Saltar al contenido principal
How to Fix a Leaning Wooden Gate
TenzinY
TenzinY y otro contribuidor
Última actualización: December 13, 2023
5 - 10 minutos
Fácil
Introducción
Ir al paso 1
Use this guide to fix your leaning wooden gate. Wooden gates start to lean downwards over time as the latch cannot withstand the weight of the door. Fix your leaning wooden gate by installing a Spring Loaded wheel. Installing the wheel provides a permanent fix, ensuring the door stands straight and well balanced.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: paso 1, imagen 1 de 2 How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: paso 1, imagen 2 de 2
    • Begin by measuring the gap under the gate to determine the exact height needed for correction.
  2. How to Fix a Leaning Wooden Gate: paso 2, imagen 1 de 1
    • Choose any object that is the same size as the measured gap.
    • Place the selected object under the gate to ensure the gate is level and straight.
  3. How to Fix a Leaning Wooden Gate: paso 3, imagen 1 de 3 How to Fix a Leaning Wooden Gate: paso 3, imagen 2 de 3 How to Fix a Leaning Wooden Gate: paso 3, imagen 3 de 3
    • Place the wheel on the side where the door is leaning down.
    • Mark the hole location for drilling.
    • Use masking tape only if the door is the same colour as your marking object.
  4. How to Fix a Leaning Wooden Gate: paso 4, imagen 1 de 3 How to Fix a Leaning Wooden Gate: paso 4, imagen 2 de 3 How to Fix a Leaning Wooden Gate: paso 4, imagen 3 de 3
    • Drill holes on the marked circles.
    • Ensure your holes are the same size as the screw you are using.
  5. How to Fix a Leaning Wooden Gate: paso 5, imagen 1 de 2 How to Fix a Leaning Wooden Gate: paso 5, imagen 2 de 2
    • Attach the wheel and place the screws .
    • Depending on what the kit provides, use a wrench to tighten the bolts or a screwdriver to tighten the screws.
    • Ensure that the screw is tightened securely to prevent a loose wheel.
  6. How to Fix a Leaning Wooden Gate: paso 6, imagen 1 de 2 How to Fix a Leaning Wooden Gate: paso 6, imagen 2 de 2
    • Remove the object you placed underneath.
Conclusión
Test out your newly added wheels, if it is wobbly make sure to tighten the wheels again.
TenzinY
Miembro Desde 09/08/23
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 37
Ultimos 30 días: 45
Todo El Tiempo: 253
