Saltar al contenido principal
How To Remove Bike Rust With Lemon Juice
Eric Robinson
Eric Robinson y 4 otros contribuidores
Última actualización: August 2, 2019
15 - 30 minutos
Fácil
Introducción
Ir al paso 1
This step-by-step guide will provide the user with a quick and easy way to remove that unappealing rust that builds up on exposed metal parts on bicycle brakes. Unwanted rust can inhibit the proper function of your brakes. This guide can be used on a variety of bike brakes which has exposed metal parts and is susceptible to rust.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. How To Remove Bike Rust With Lemon Juice, How To Remove Bike Rust With Lemon Juice: paso 1, imagen 1 de 2 How To Remove Bike Rust With Lemon Juice, How To Remove Bike Rust With Lemon Juice: paso 1, imagen 2 de 2
    • Put on Latex gloves
  2. How To Remove Bike Rust With Lemon Juice: paso 2, imagen 1 de 1
    • Generously apply the lime juice onto steel wool
    • Keep the lime juice out of eyes and any open wounds due to the acidic qualities of the lime juice
  3. How To Remove Bike Rust With Lemon Juice: paso 3, imagen 1 de 3 How To Remove Bike Rust With Lemon Juice: paso 3, imagen 2 de 3 How To Remove Bike Rust With Lemon Juice: paso 3, imagen 3 de 3
    • Vigorously rub the steel wool with lime juice on the rusty parts of the brakes
  4. How To Remove Bike Rust With Lemon Juice: paso 4, imagen 1 de 1
    • Wipe off the excess lime juice and the removed rust particles with paper towels to make your bike brakes look as good as new!
Conclusión
After the user has completed these 4 simple steps, the exposed metal parts should be free of rust and ready to use. Repeat these steps for any other rusty metal parts of bicycle brakes.
9 personas más completaron esta guía.
Eric Robinson
Miembro Desde 04/09/15
485 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 30-2, Green Spring 2015 Miembro de Cal Poly, Team 30-2, Green Spring 2015
CPSU-GREEN-S15S30G2
4 Miembros
4 Guías creadas
Un comentario
the title says Lemon Juice, while all the references inside refer to Lime Juice.
richardwstevens - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 3,407
