HTC Vive Controller Trigger Replacement
Introducción
Ir al paso 1The HTC Vive controller trigger may be faulty and may not be detecting clicks from extended use. The motherboard has to be removed in order to access the trigger. This guide will show you how to replace the trigger.
Qué necesitas
Turn over the Vive controller so that the bottom saucer is facing up.
Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the top of the motherboard.
Use the T5 Torx screwdriver to remove the four black 5.2mm screws from the inner part of the trigger.
6 personas más completaron esta guía.
2 comentarios
It is possible to access and replace the trigger without having to disconnect any of the cables. I have done this with 3 controllers already.
Just ignore the steps saying to disconnect the cable, move parts to the side and be careful.
No disassembly fix for a broken spring: Sling a rubber band under the trigger.
