Saltar al contenido principal
HP dv5-1125nr WLAN Card Replacement
Cory Mayer
Cory Mayer y 5 otros contribuidores
Última actualización: July 23, 2021
15 - 20 minutos
Moderado
Ruta Pintoresca
Introducción
Ir al paso 1
If your wifi isn't working, it might just be a loose connection to your wireless card. Follow this guide to replace your wireless card.
Qué necesitas
Herramientas
Ver más…
  1. HP dv5-1125nr WLAN Card Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr WLAN Card Replacement: paso 2, imagen 1 de 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr WLAN Card Replacement, Hard Drive: paso 3, imagen 1 de 2 HP dv5-1125nr WLAN Card Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr WLAN Card Replacement: paso 4, imagen 1 de 1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr WLAN Card Replacement: paso 5, imagen 1 de 2 HP dv5-1125nr WLAN Card Replacement: paso 5, imagen 2 de 2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr WLAN Card Replacement: paso 6, imagen 1 de 2 HP dv5-1125nr WLAN Card Replacement: paso 6, imagen 2 de 2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr WLAN Card Replacement: paso 7, imagen 1 de 2 HP dv5-1125nr WLAN Card Replacement: paso 7, imagen 2 de 2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
  8. HP dv5-1125nr WLAN Card Replacement, WLAN Card: paso 8, imagen 1 de 1
    • Locate the wireless card and the two wires attached to it.
    • Caution: Prying on the WLAN card wires in the wrong direction could damage your wireless card. Make sure to lift straight up when removing the wires.
    • Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
  9. HP dv5-1125nr WLAN Card Replacement: paso 9, imagen 1 de 2 HP dv5-1125nr WLAN Card Replacement: paso 9, imagen 2 de 2
    • Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
  10. HP dv5-1125nr WLAN Card Replacement: paso 10, imagen 1 de 2 HP dv5-1125nr WLAN Card Replacement: paso 10, imagen 2 de 2
    • Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot.
    • The card is now free from your computer.
Conclusión
Una persona más ha completado esta guía.
Cory Mayer
Miembro Desde 04/01/14
891 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-15, Regan Spring 2014 Miembro de Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 35
Todo El Tiempo: 1,219
