Saltar al contenido principal
HP Stream x360 11-p015wm Motherboard Replacement
Meredith Buganski
Meredith Buganski y 2 otros contribuidores
Última actualización: December 26, 2019
25 minuto
Moderado
Introducción
Ir al paso 1
This guide will walk you through the steps of replacing the motherboard in an HP Stream x360 11-p015wm. The motherboard is an important part of the computer hardware and contains multiple main components. Follow along, step-by-step to safely remove your motherboard and then follow the instruction in reverse to reassemble your laptop! Be sure to back-up your files before undergoing this repair.
Qué necesitas
Herramientas
Ver más…
  1. HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Motherboard Replacement: paso 2, imagen 1 de 1
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Motherboard Replacement: paso 3, imagen 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Motherboard Replacement: paso 4, imagen 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: paso 4, imagen 2 de 2
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
  6. HP Stream x360 11-p015wm Motherboard Replacement: paso 6, imagen 1 de 3 HP Stream x360 11-p015wm Motherboard Replacement: paso 6, imagen 2 de 3 HP Stream x360 11-p015wm Motherboard Replacement: paso 6, imagen 3 de 3
    • Unplug the wire attaching to the battery to the motherboard using the tweezers.
    • Remove the battery.
  7. HP Stream x360 11-p015wm Motherboard Replacement: paso 7, imagen 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
    • Remove the silver plate cover.
  8. HP Stream x360 11-p015wm Motherboard Replacement: paso 8, imagen 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
  9. HP Stream x360 11-p015wm Motherboard Replacement: paso 9, imagen 1 de 3 HP Stream x360 11-p015wm Motherboard Replacement: paso 9, imagen 2 de 3 HP Stream x360 11-p015wm Motherboard Replacement: paso 9, imagen 3 de 3
    • Detach all remaining wires from the motherboard using the tweezers.
  10. HP Stream x360 11-p015wm Motherboard Replacement: paso 10, imagen 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: paso 10, imagen 2 de 2
  11. HP Stream x360 11-p015wm Motherboard Replacement: paso 11, imagen 1 de 2 HP Stream x360 11-p015wm Motherboard Replacement: paso 11, imagen 2 de 2
    • Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
    • Remove the motherboard.
Conclusión
Equipo
IUPUI, Team S2-G3, Stella Fall 2019 Miembro de IUPUI, Team S2-G3, Stella Fall 2019
IUPUI-STELLA-F19S2G3
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 737
