Saltar al contenido principal
HP Spectre x360 15-bl012dx Motherboard Replacement
Matthew McClure
Matthew McClure y 4 otros contribuidores
Última actualización: May 27, 2022
45 minuto - 1 hora
Moderado
Introducción
Ir al paso 1
If your laptop is not working, the motherboard may be to blame. The process of replacing the motherboard may also fix screen, battery, booting, and charging issues. This guide will show you how to replace the motherboard. Please note that this guide is specific to the HP Spectre x360 15-bl012dx.
Please visit our Troubleshooting Page before beginning disassembly.
Please make sure the laptop is turned off and disconnected from the charging adapter before you begin to this repair.
Qué necesitas
Herramientas
Ver más…
  1. HP Spectre x360 15-bl012dx Motherboard Replacement, Battery Replacement: paso 1, imagen 1 de 2 HP Spectre x360 15-bl012dx Motherboard Replacement, Battery Replacement: paso 1, imagen 2 de 2
    • Power off the device before beginning disassembly.
    • Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
    • Next, remove the four visible Torx T5 3 mm on the sides.
    • Keep track of all screws.
  2. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 2, imagen 1 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 2, imagen 2 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 2, imagen 3 de 3
    • Please note the upper two feet are already removed. The device was given to us this way.
    • Remove the two upper feet using an opening tool or spudger if they are still in place. The upper feet are closer to the hinges for the screen.
    • Remove the two 8 mm Phillips #1 screws under the feet.
    • These are the final screws to remove from the back panel. In total, you should remove eight screws between Steps 1 and 2.
  3. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 3, imagen 1 de 1
    • Use a spudger to pry the back panel off of the laptop. Work your way around the perimeter of the device to loosen the connection.
    • Take the back panel off of the laptop.
  4. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove six 4 mm screws securing the battery.
  5. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 5, imagen 1 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 5, imagen 2 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 5, imagen 3 de 3
    • Unplug the battery connector located on the motherboard.
    • Remove the battery from the laptop.
  6. HP Spectre x360 15-bl012dx Motherboard Replacement, Solid State Drive (SSD): paso 6, imagen 1 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement, Solid State Drive (SSD): paso 6, imagen 2 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement, Solid State Drive (SSD): paso 6, imagen 3 de 3
    • Using minimal force, lift the locking bars on the USB board ZIF connector using a plastic opening tool or fingernail and pull out the ribbon cable.
  7. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 7, imagen 1 de 1
    • Using your fingers, remove the USB ribbon cable from the motherboard above the fan.
  8. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 8, imagen 1 de 2 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the 3 mm Phillips #1 screw that secures the solid state drive to the board.
    • Please note this laptop was not supplied with an SSD, so this is not the same SSD you will find in your device.
  9. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 9, imagen 1 de 1
    • Slide the SSD card out of the connection at a 45 degree angle so that the SSD teeth are not bent.
  10. HP Spectre x360 15-bl012dx Motherboard Replacement, Motherboard: paso 10, imagen 1 de 2 HP Spectre x360 15-bl012dx Motherboard Replacement, Motherboard: paso 10, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove two 3 mm screws from each fan.
  11. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 11, imagen 1 de 2 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 11, imagen 2 de 2
    • Remove the six 2.5 mm Phillips #1 screws holding the heat sink in.
  12. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 12, imagen 1 de 2 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 12, imagen 2 de 2
    • Pop up the eight tabs on all the ZIF connectors on the motherboard. This can either be done with a spudger or your finger nail.
    • Looking at the back of the laptop, there are two ZIF connectors in the top right (one should already be disconnected from the SSD removal), one in the top left, and 5 on the bottom. Indicated by red squares.
  13. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 13, imagen 1 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 13, imagen 2 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 13, imagen 3 de 3
    • Remove the five remaining connectors from the motherboard. Two on the bottom left, one on the bottom right, and one on the top right. These connectors pull up off the motherboard with no clips.
  14. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 14, imagen 1 de 2 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 14, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the 2 mm screw from the Wi-Fi card that secures it to the motherboard.
    • Slide the Wi-Fi card out of the slot.
  15. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 15, imagen 1 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 15, imagen 2 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 15, imagen 3 de 3
    • Snake the speaker wires out of the plastic routings on the fans that hold the wires in place.
    • Lift the fans and heat sink out.
    • Remove the black heat shield under the heat sink.
  16. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 16, imagen 1 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 16, imagen 2 de 3 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 16, imagen 3 de 3
    • Clean the old thermal paste off of the heat sink, cpu, and gpu using isopropyl alcohol and a paper towel. The higher the percentage of the alcohol, the better. I used 91%.
    • Remember to apply thermal paste before installing the new motherboard with fresh thermal paste! A pea sized amount is plenty.
  17. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 17, imagen 1 de 2 HP Spectre x360 15-bl012dx Motherboard Replacement: paso 17, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove four screws from the motherboard.
    • Two 3 mm screws
    • Two 2 mm screws
  18. HP Spectre x360 15-bl012dx Motherboard Replacement: paso 18, imagen 1 de 1
    • Remove the motherboard. Pull up the right side first, then pull it out.
Conclusión
Una persona más ha completado esta guía.
Equipo
Clemson, Team 1-1, Hunter Spring 2022 Miembro de Clemson, Team 1-1, Hunter Spring 2022
CLEM-HUNTER-S22S1G1
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 37
Todo El Tiempo: 1,625
