HP ProBook x360 11 G5 EE Wireless Card Replacement
Introducción
Ir al paso 1The guide will show how to replace the wireless card in your HP ProBook x360 11 G5 EE laptop. The Wi-Fi card allows you to connect to the internet wirelessly. If the laptop’s Wi-Fi keeps on connecting and disconnecting, has a weak connection, or simply cannot find any networks regardless of troubleshooting, you may have a faulty wireless card.
Qué necesitas
Remove the 4.1 mm screws with a T5 Torx screwdriver.
Remove the 4.1 mm screws using a JIS #0 screwdriver.
Disconnect the ribbon wire from the motherboard by lifting the small flap that holds it in place.
Una persona más ha completado esta guía.
